How many 12-2 MC cables can be ran through a single hole in a 2 x 4 wood stud? I know with romex it is 3. Is it different for MC cable?
Thanks!
Thanks!
Agree, also don't know where people keep coming up with 3 cable limit. If you do require ampacity adjustment most of the time you can still have 4 cables before you need to upsize anything, unless there is more then two current carrying conductors in any of the cables. The key here is number of current carrying conductors not number of cables.Running cables through a hole is not automatically considered bundling if there is air space between the cables in the areas between the studs. Also there is no 3 cable limit for NM cable.
I agree with you, but my inspectors don't.Running cables through a hole is not automatically considered bundling if there is air space between the cables in the areas between the studs. Also there is no 3 cable limit for NM cable.
d. Not more than 20 current-carrying conductors are installed
without maintaining spacing, are stacked, or are
supported on“bridle rings.”
I am not sure the NEC agrees with you.
Consider that the NEC considers MC run through bridal rings as bundling as evidenced by this.
Notice it says without maintaining spacing OR supported on bridal rings.
In my mind running through a stud every 16" is much more bundled than running through a bridal ring perhaps every 6'
I would disagree, just because that section mentions bridle rings does not mean it applies to all similar installations like running through stud holes. Although I do agree with your logic it simply says that if you use bridle rings then you consider them bundled.
How can something held loosely together every 6' be bundling while something tightly bundled every 16" is not?
I can't follow that logic.
