- Lockport, IL
- Semi-Retired Electrical Engineer
I have raised other points that you choose not to address. Usually in court you do not have that luxury.
I have gone back and looked, and I did not see any point you made that I have not already addressed. So I am going to invoke ?Charlie?s Rule?: The code says what it says. And what it says is that the disconnecting means must be in sight.As I said, in court you would not have the luxury of ignoring other relevant points I've raised and you failed to address.
Now if you wish to say, as an example, that in a particular installation the ?disconnecting means? consists of four components (e.g., a shunt trip button, a breaker, the conductors between them, and the power source that actuates the shunt trip), I can accept that. But having declared this ?set of components? to be the ?disconnecting means,? we return to the words in the code: the disconnecting means must be in sight. Whatever constitutes the ?disconnecting means,? be it one component or a set of components, the disconnecting means must be in sight.
You might as well say that if three of the components (namely the button, the breaker, and the power source) are in another room, and the fourth component (namely the conductors) is run within sight of the motor, then you have satisfied the words in the code, because ?at least one portion of the disconnecting means is in sight.?
