I have been studying about motors and sizing conductors also disconnect means and things, and something puzzles me.
I do not understand the purpose of putting a disconnect with or without fuses. The only difference to me is if you OCP is higher then you FLC of the motor then you use fuses at the disconnect. I really need help with understanding this so I can move on with studying.
Can anyone help me understand when fuses should be used compared if you just use a safety switch or even if you do have to use fused if you have an OCP that is the correct size. Too much in the head and ignorance is still there.
Thanks.
Thanks.
