measuring FOP with simpson
i guess im just crazy or something. if i measure 120v i will blow the meter but if i measure across a breaker each side is the same potential pretty much and will measure millivolts
Start with the above-the-line-voltage setting on the meter, and lower the range one click at a time as far as you dare.
As for actual damage, you'd have to see if maximum voltage inputs are specified in the meter's documentation.
Now, if the breaker decides to trip just as you are making a measurement, the meter will see the full line voltage.
