I am a little unclear by what the code states in the exceptions under article 517.30(3). I have an emergency system that serves patient care areas. The main components of the system comprises of a branch circuit panel, an emergency circuit distribution panel, an automatic transfer switch and a generator. I am foggy on the run between the transfer switch and the generator because it can be put in the slab which brings me to exception 4. That particular run doesn't serve patient care, but the system does. So my question is, can I use PVC Sched. 40 for this run per exception 4?
Thanks.
David
Thanks.
David
