Mechanical room
Sounds as if your whole department should be eligible of something akin to the "Darwin Awards: :)
You are wrong and/or misunderstanding. That makes absolutely no sense whatsoever. That would mean people cant install an SPD.
Nope I been thru many projects you go by version they the AHJ adopted not what you think is the updated version or version you like.
Like I said if it was that essential AHJ would amend the local code immediately. Thats the way it is around here or else wait till code you like version adopted
You are misunderstanding what using current adopted code means.
The code would have to SPECIFICALLY disallow something for an AHJ to fail it. You are either misunderstanding or the AHJ is off their rockers! I choose to think the former!
I also once heard of case accident where judge said why has something other than adopted version is used in plans and it was not caught!
