Med Voltage Cables - stress cones required
KarlS
Houston, TX
I have a project where the customer is sending me a 45KVA XFMR 4160V-208/120V. This transformer will cable to a Eaton-Cutler hammer ampgard motor starter. My questions is - am I required to use MV Shielded cable for this application. The transformer is equipped with two mechanical lugs for about #6 cable. A stress cone clearly will not fit here without modifications. The modifications will more than likely void the xfmr warranty.
Also the transformer will sit next to the ampgard starter.
Thanks in advance.
