LAYMAN JOE
35kv cables terminate at a fused Air Switch. These cables go through separate CT's for metering ONLY. This is not service equipment. These CT's are not for the protective relay system, they are only for metering. When cables go through CT's for protective relays you must always take the drain wire back through the CT before grounding it.
There is an ongoing debate as weather to take the drain wire back through the CT for metering. Many experts I know say you DONT take it back through for metering and many other experts say that you always take the drain wire back through for every application.
Oh how I hope someone on this board would enlighten me.
