weressl
Esteemed Member
does anybody have or know where i can download and print some documentation that says using a megger is a good idea? im talking about something, for example, from an arc fault breaker manufacturer that mentions the use of a megger. i hope you guys know what im talking about
i know theres plenty of information on here i just need something i can print out thats from a major electrical equipment manufacturer or something like that
To aswer simply:
An Ohm-meter is designed to measure the conductivity of an electrically conductive element, such as wires, coils, windings etc. It is non-voltage dependent.
A Megger or (genericly) insulation tester is designed to test the resistance of an element that is designed to insulate/isolate electrically conductive elements form each others or from gound. It is voltage dependent as an element may exhibit high resistance at low voltages but reveals low resistance when it's designed operating voltage is applied.
