Since it's a 167, it's likely single phase. 3 of these makes a 500KVA bank.
What kind of a megger do you have? Some of the less expensive digital units may not be able to 'fill up the core' on a xfmr this size. A hand-crank one will though.
Has this xfmr ever been energized? If so, and it is oil filled, you'll likely be ok. If it's a dry-pack, you might need to burn the moisture out of it to get it to pass. In northern Nevada you wouldn't, humidity runs in the single digits frequently). If it's never been energized, there are other tests that would be useful. A 167 can make a pretty big bang.
