In order to do a PI test you'd need a megger with a 1000G or 1Tera ohm max range. Many handhelds won't even come close to that.
His readings are not near that high, and unless his PI would be way over a 2.0 or 3.o would he need a that kind of equipment....
I have ran PI's with a crank, although not minute accurate, and your arm gets mighty tired, it will give you a definite indication of the capacitance values. Its really pretty simple the resistance values are either getting better or going south.....
I cant remember, what's the 3 mintute test called? It's a decent test for go/nogo
