Mstr of some
New member
- Covington, WA
Can unspliced conductors (including the EGC) pass thru isolated metal boxes and adjoining raceways without bonding the EGC to the boxes? Code reference?
If I'm not mistaken, it says that if the circuit conductors are spliced within the box, it must be bonded via the EGC, even if it isn't spliced...If grounding conductor(s) are ran with the circuit(s), regardless the type of conduit used, and any of the grounding conductors are spliced within, or attach to equipment within the box (switches, receptacles, etc.) the spliced grounding conductors must be bonded together and to the box.
