Dave D'Amato
New member
Question....
In reading the NEC code on metal objects not carrying current I'm having difficulties understanding the following....
From the Service power Meter, our construction staff has been terminating Neutral; to ground on the load side. Then this feed is brought to our field service cabinet and tied to another ground rod... All of which we feel is causing power and ground loop issues...
In discussing with these folks, the reply is it's code.... The NEC articles seems to state otherwise....
I can understand the line side of Neutral to ground terminations but no on the load side... Is this reference to code correct?
If so, this depicts Neutral and Earth ground are as one and if this is the case then why install/run a Black (HOT), Neutral (WHITE) and Ground (Green) conductor where two are electrically the same....
This just doesn't seem correct to me....
Thanks,
Dave
Thanks,
Dave
