Found this statement looking through some old Code Questions of the Day:
"When a metal raceway containing a equipment-grounding conductor is connected to a metal box, the equipment-grounding conductor(s) must be spliced together and connected to the box. This "redundancy" assures continuity of the ground-fault path in the event that either the metal raceway system or the EGC system fail to be continuous."
Is there a actual code reference or is this just a recommendation?? Doesn't seem practical on a large job with hundreds of 4" square junction boxes that may not even contain splices and are being used as pull points. Thanks
[ November 08, 2004, 02:52 PM: Message edited by: fortunms ]
