sureshbkhanal
- Chantilly VA
- Inspector
Does code allow you to use metal sheet screws for mounting receptacles ? What is the section of the code in NEC 2014 book? I look forward to hearing from you.
That's when you reach for the drywall screwSo what do you do when the machine screw threads strip out of a box in the wall ?
JAP>
Table 300.5What is minimum cover depth for PVC conduit with 2 inches of concrete cover in a heavy traffic area ?
Further, even a fine-thread sheetrock screw has threads too course to be effective on something as thin as box mounting ears.Next size up on machine screw usually works, without violating 406.5. A sheetrock screw can have exceptionally sharp edges that will travel offcourse while inserting into box, greater likelyhood of damage to wiring if it does run out. Also the bugle head can also be sharp and I've seen wire damage because someone used it to mount a box.
