In a install of a PVC junction box
Connectors entering the box would not be allowed to be metal unless you use s grounding bushing
I saw a service done with SEU. The load of the meter to the panel was sleaved in PVC.
The sleave stopped short of the panel inside the dwelling by about a foot and went from a PVC female adapter to a metal two hole squeeze connector to choke the SEU before entering the panel with s two hole squeeze connector.
Is the metal squeeze connector at the end if the PVC conduit not correct ?
Thank you
Thank you
