david
- Pennsylvania
Fastened / Securely fastened / supported.So, a Minerallac and a 1-hole strap. Technically, he's correct, but in this specific case, an elbow is not going to expand enough to overcome the flexibility of a Minerallac. Long straight runs are the main concern.
352.30
Fastened to allow movement from thermal expansion or contraction. Then adds shall be securely fastened in accordance with (A) (with in 3ft)
352.44 expansion fittings between securely mounted items
PVC conduit fastened at intervals that allow expansion securely fastened with in 3ft of securely mounted items
I do not see a violation of the hanger or the two hole strap in the OP picture
If the tightness of such a hanger or strap was said to be an issue simply do not make it that tight
