What do you install the drywall with? I thought they used tek screws?
First, I'm an electrician. I don't install drywall.
I think they typically use drywall screws.
Unless the studs are light weight these ones are popular here and I know for a fact you can zip them into EMT or a 4" sq blank cover easily.![]()
300.4(A) is for cables through bored holes in wood members.
Neither do I but from what I've seen the screws they use will go right a "nailing plate"
Your right, 300.4(A) does not apply to MC cable run through metal framing members.
You just can't run the MC cable parallel to the metal stud at a distance less than 1-1/4 from the nearest edge without protection.
Chris
Yup, so just install a Colorado Jim or similar strap and you're good to go. No metal plates required.
A Colorado Jim is a Caddy CJ-6 used for MC stacking
I was wondering,"Why do they call a Cable stacker a Colorado Jim?"
Then I saw the Caddy number "CJ-6". LOL Clever.
Yes, but which came first?I was wondering,"Why do they call a Cable stacker a Colorado Jim?"
