When mounting a panel in metal studs, do you have to frame it plywood. I why you would have to but the job I on commercial job they framed all panels with plywood. I need to add another panel and don’t see the purpose in it. I don’t do commercial that much.
I don't see any purpose for it. Who knows why the original installer did it. Maybe the only fasteners they had on the truck were wood screws.
I would not be inclined to follow existing in this case. I like to match existing where I can, but I refuse to be "stuck on stupid" or copy an otherwise obtuse design.
seems a metal cabinet fastened to a stud on each side of it would give them a lot of rigidity when compared to a one gang device box just fastened to the side of one stud.I'd venture that most people I've known don't particularly trust metal studs and how easy they twist before substrate is applied so they used plywood to add rigidity.
Sent from my SM-G930V using Tapatalk
.... It's a better installation than just toggle bolting the panel to the drywall.
We always install a piece of the bottom track to the studs on both sides of the panel. Give a nice flat sides and also strengthens the panel.
