Use of flexible metal conduits as an equipment grounding conductor where permitted is limited to six feet length of flex. Some confuse this as a 6 foot limit on flexible conduits, but it is only a limit on how long it can be used as an EGC. Pull in a separate EGC and you can have any length you want.Is there an official rule in NEC about max length of metallic liquid tight? Everyone says 6 feet, but can't find in code book. For example is it acceptable to come out of a disco and into an outdoor ac unit with 10 feet of metallic tight if properly supported?
Thanks. Do you know which article this is?
