Meter bank jumper
The electron man
Nyc
the company I work for has us jump all the meters on the meter-bank with #12 wire so we can test all the sub panels in the apartment and the branch circuits
The ocpd for eaxh apartment is 100A
How is using a #12 jumper safe ?
infinity
New Jersey
Journeyman Electrician
If there is little to no load nothing will happen to the jumper. If you're running high wattage electrcial appliances then there might be an issue.
Hv&Lv
Engineer/Technician
You're jumping across the meters?
LarryFine
Henrico County, VA
Electrical Contractor
You're effectively installing fusible links. My first boss tested transformers with #18 wire.
