Meter base location
865resi
Tennessee
My GC is adding on to an old rental house. He is turning it into a duplex with the new square footage. The old house only has a meter outside, no disconnect. He wants the meter and disconnect for the new part of the dwelling on the opposite side of the original meter location. The original meter will not move. Is this satisfactory with the 2017? Local utility does not care, we use smart meters.
Tne NEC has no input on meter location. You mentioned "duplex". Is the plan for one service drop or lateral.
I believe he wants one meter on one side of the duplex and the other on the opposite side of the duplex. I assume 1 drop and one lateral.
My guess if there is a firewall between the structures then this is okay
Yes, this is the correct situation. Thank you.
