- Simi Valley, CA
Around here you better not get caught with one of those keys. They even charge the POCO guys if they lose one.
Why, are they considered "controlled substances" or something like that? Possession is one thing, actually using them is another. I also own several tools that may be used to open the lock, but that is not considered wrongdoing, using them to open the lock that I am not authorized to open is what is wrong.Around here you better not get caught with one of those keys. They even charge the POCO guys if they lose one.
Don't know all I know is that I lived next door to a guy that was pretty high up in one of the local POCO's and I deal with the other local POCO on a daily basis and when I asked both for a key they laughed at me. The one guy said that if he ever lost his meter key that they would fine him $150.
But then again, I can usually have a meter unlocked within a few hours with just a phone call.
Somethings can be considered illegal to merely possess whether you intend to or actually use them.
IIRC, in MD it is illegal to possess a "slim jim" to unlock a vehicle unless you are registered for its use by the State Police.
well I guess it is illegal for me to posses things like grinders, saws, drills, torches... I may try to use them as a key for a lock![]()
Reminds me of the joke about the the Game Warden and woman sitting next to some fishing gear...He wanted to ticket her for fishing with no license because she had all the equipment for fishing. She started screaming "RAPE!!" After calming her down he told her "I have not raped or even touched you!!" "I know, but you have all the equipment."
I know, OT.
I had to open a PSE&G (NJ) meter to repair a service. The correct size allen key to use is 9/32 for anyone interested.
HAPPY NEW YEAR!!!
So does this mean you can be sent to prison if you have a 9/32" allen wrench? I think I have several of them![]()
All of the meter lockrings I've seen have a slot for a seal. If we as the dreaded POCO see a missing seal, we assume tampering and pull the meter to inspect. That means extra manhours. Pulling a meter may not seem like a big deal, but I've been in the utility industry for almost 40 years, and pulling a meter is probably the most dangerous part of the job. There is no way of knowing what's behind the meter. Missing cover bolts, broken jaws that can pull out and short to ground, etc. The meter is usually ahead of any protective devices and the only thing that will clear a line side fault is the fuse on the transformer. That can take a while and do a whole lot of damage first. If you don't wear the proper PPE, it can get really ugly. That said, as a utility it would be a setup for a huge liability suit if we let non-utility people access the utility side of the service and something BAD happened. Not worth it.
When I was younger I would sometimes changeout main breaker or sometimes entire panel box when poco proved to be unreliable about showing up and would specifically forbid me to cut seal, this may have been dangerous also. Lately I have avoided working these things hot and have found ways not to do it.All of the meter lockrings I've seen have a slot for a seal. If we as the dreaded POCO see a missing seal, we assume tampering and pull the meter to inspect. That means extra manhours. Pulling a meter may not seem like a big deal, but I've been in the utility industry for almost 40 years, and pulling a meter is probably the most dangerous part of the job. There is no way of knowing what's behind the meter. Missing cover bolts, broken jaws that can pull out and short to ground, etc. The meter is usually ahead of any protective devices and the only thing that will clear a line side fault is the fuse on the transformer. That can take a while and do a whole lot of damage first. If you don't wear the proper PPE, it can get really ugly. That said, as a utility it would be a setup for a huge liability suit if we let non-utility people access the utility side of the service and something BAD happened. Not worth it.
exact why we went to these years ago View attachment 7885
I don't care for the lugs that break off and are pulled out with the meter either.
sounds like a job for the new apprentice.Aren't those things aimed at the meter glass shattering? OTOH, what are the actual boundaries and incident energy for a 200a residential service? I've read some things recently that suggest most 100a/200a residential services would be HRC 1. Me- I'll have someone else pull the meter or cut the drop.
