Meter Points
I have installed the quadlogics before. You have 3 ct's for each metered point (A,B and C Phase). Most of the mini closets come with either 6 or 8 metered points (18 or 24 ct connections). What exactly are you trying to figure out?
The 3,6,9 and 12 metered points is for a single phase application on a 120/208 service where you are only monitoring two phases. So you would have a ct on only two phases of the metered points (2 phases are being monitored instead of three). Each set makes a metered point.
So there are places in the country where there is no physical meter per tenant and just one of these boxes.
Yes, these are for a sub-metering application. I have usually installed these in commercial applications, tenant spaces, and metering of independent equipment.
