paul renshaw
- Cordova, Maryland
Anyone know why that a meter will read Hz from the utility supply, but when the same meter is used to check volts and Hz on a newly installed residential generator, before putting a load on it, it will not read Hz. The meter mfg could not give a reason, or be of much help, they just said that it will not read it from the generator. It is a true RMS multi-meter.We are going to try a different brand in the future and see if it will work, but it may be some time before it can be done.
