I was asked how to install a meter to monitor basement suites power consumption, but not with the power authority's meter. Is there a product that can be installed to monitor power consumption to an basement suite inexpensively?
I just install a regular meter base. my local supplier also has meters. the E Mon D Mon is very spendy in comparison.Also I dont think its my responsibility to monitor whta the customer does with the meter readings he gets.Thats between him and the poco. I just install per code and get paid.
110717-1436 EDT
texie:
I went to the website you referenced. I could find no useful information.
What are the specifications for each part? How does the system or systems work? How does their current sensor work? Implication is that it is not a normal type of current transformer. Thus, is it a Hall sensor or some other kind of magnetic field sensor? What is the working voltage range? Like 100 to 130 V or 85 to 125 or what? What does their current rating mean? What kind of data is available? What is the sample rate? What is the accuracy? How good is the performance as the load power factor is varied from 1.0 to 0.0 ? And many more questions.
As bad as the TED website is I can learn more about their system from their website than about emon systems from the emon site.
You're right-the standard POCO style meter is cheaper-but with a little CT type like the EMON (or similar-I don't want to offend) you can meter multiple branch circuits just by passing them thru the CT's of the same phase and they add to the reading. This is very handy since often in these installations there are multiple branch circuits to the area you want to measure.
Another problem with a POCO style meter is I have never seen a meter socket without a permanatley bonded neutral which is a problem if used for other than service equipment.
