Mr. Serious
- Oklahoma, USA
- Electrical Contractor
What currently-made breakers are listed for use in this panel? I first made the mistake of thinking it was a Challenger panel from the 1990s because of the Challenger main breaker, but that must be a replacement, because the other breakers under the main are Crouse-Hinds and the label says it is a Crouse-Hinds panel
I did an internet search and came up with one post where someone said the proper breakers to use in an old Crouse-Hinds panel are Siemens breakers. And, I see the original breakers were marked as type MP, which is the same as currently-manufactured Murray breakers, which I think are the same or similar to Siemens type QP. So, is that correct?
There was a used 20A tandem breaker in there that was arcing to the bus. I told the customer it wasn't the correct breaker for the panel, then realized I may have spoken too soon. It didn't have a brand but was marked "type A and C," so I think it was a Challenger breaker. I also think the arcing was more due to the breaker being used when installed, rather than the fact it was not listed for this panel, so I probably shouldn't have made an issue of that. But, since I did, I want to make sure that any breaker I use in this panel is listed for it.
