knaack134
- Chicago IL
When you specify wire type what exactly does coated or uncoated mean. I am assuming that a THHN conductor would be considered coated. Any thoughts?
I agree with your first statement; however, my understanding is that the coated wire was a .001" tinning that was for the purpose of making up the soldered connections. The diameter of the conductor was actually reduced by .002" and then a .001" thickness of tinning was added to get the same diameter. Therefore the resistance per 1000' was a little higher. Since my understanding is different, I would like to see some verification as to which one of us is correct. :smile:. . . My understanding is:
Uncoated copper is typical building conductors such as THHN, XHHW, etc. (bright copper with no plating)
Coated copper will be plated copper conductors which are typical on high temperature conductors and some specialty conductors. . .
