kwired
Electron manager
- NE Nebraska
- EC
Not after I stenciled it with my company name LOL.... Or ....
That might not matter.
Some of that may be true however I don't believe the locksmith as I've re-keyed too many of them myself with no cylinder problems. Same is true with plumbing repair parts and while I don't do the volume they do I have not had an issue that stands out or indicates a trend.Reminds me of when, a number of years ago, a friend of mine bought a Milwaukee corded Hole Hog at HD. The first time he used it was to bore some 2" holes with a Roto-Bore bit through 2x framing for conduit. On the very first hole the gears stripped. He brought it back and HD replaced it. He goes back to the job and the exact same thing happens again with the new drill. So, finally figuring it out, he gets his money back from HD and goes to a tool distributor to purchase the same model Hole Hog. No problems to this day.
Moral of the story is that I never recommend buying power tools from the Big Boxes. They buy such large volumes from the manufacturers that they can dictate a low price point and the manufacturers make the product especially for them while still maintaining their profit so something has to go.
From talking with other trades this holds true for a lot of other stuff too. I've had locksmiths tell me how Schlage and Kwickset from HD is nothing like the same products they get from their distributors. They won't rekey HD locksets because once you take the cylinder apart it won't stay together. Painters talk about Purdy paint brushes. Purdy is supposed to be professional grade but not at HD. Plumbers complain about HD faucets. Even though it may say Kohler or Delta it ain't the same. Don't expect regular repair parts to work.
At first I chalked this up to sour grapes but seeing is believing. Makes you wonder what they do to electrical products that we can't see.
-Hal
What cap? The only cap I can think of is the one over the springs, and you don't remove that (at least for the locks I've used) Most deadbolts you pull the cylinder out and twist the key 180° to access the holes opposite the springs. Alternatively, you push the cylinder out with a shaft of the same diameter. Not once have I had to deal with a "cap."You have done it personally or had a locksmith do it? I've seen it personally. If you beat the cap on over the pins to peen it it MAY stay on. Then again it may go flying off...
-Hal
My thoughts exactly. I do believe that some of the high-end cylinders like Schlage have a slotted cover, but all the ones I've ever touched (Weiser, store brand, etc) have been swaged and probably aren't intended to be disassembled in the field.I was always able to replace the springs and drivers through the core hole, one at a time using a slightly tapered follower. I would not even try to remove the swaged hole cover and then stake it down again.
Personally. I would not have a lot of confidence in a locksmith that has trouble with it.You have done it personally or had a locksmith do it?
Continuing off topic, I like the "brass magnet, but was perfectly happy inserting the driver a short distance using tweezers. Then jam the driver in place using the follower long enough to get the screwdriver or tool of choice to push the top of the driver the rest of the way down.My thoughts exactly. I do believe that some of the high-end cylinders like Schlage have a slotted cover, but all the ones I've ever touched (Weiser, store brand, etc) have been swaged and probably aren't intended to be disassembled in the field.
If you 're changing the top pins it would probably be easer to do it as shown here: https://www.youtube.com/watch?v=rS7DLf4RSQE
How did my discussion of hammer drill protection circuits turn into one about locksmiths? I love Mik holt forum![]()
-Hal
