I've been jousting with this windmill for so long I fear I've forgotten some of theI've always thought as iwire that a disconnect is required at the indoor fan/coil unit of a mini-split. But david's comment back in post #27 that 422.31(A) would apply in most of the smaller units seems to be correct. What say all?
details, but I want to say when that was brought into the discussion there was a problem with the listing on the unit being other than an "appliance" but that route may be worth re-investigating.
My experience has been that I have received very little input from ETL beyond "we are looking into that" and UL advises they only provide the "Standard" to which ETL refers. It appears to be a ball that no one wishes to carry.As far as the factory cables often not being compliant with NEC, what have we come to as far as NRTL value? This has been an issue since these units came to market. Why don't the NRTLs care? And the instructions that typically come with these units are an insult!
Listings are what they are, but it staggers me a little to think that TC cable can't be used without a raceway in residential settings. I just finished a job with TC cable; it's like NM, but with a jacket on steroids. It's certainly no more fragile than NM; I'd say it's actually much tougher. There seems to me to no reason, other than vendor paperwork, that TC couldn't be used anywhere NM can.
SceneryDriver
I agree that it should be acceptable based on the properties you note.
That said, from an inspectors stand point is that it remains a violation awaiting change in the Code or the listing of the cable.
If there was a failure of some type the inspector allowing such an install is standing on poor ground as long as it's a violation.
