JDB3
- San Antonio, Texas
When connecting for a mini-split system ( a heat pump system, where one unit is outside & another is typically on the wall inside) most of the time, I connect the outside unit & the a/c guy runs his power/control wire (consisting of a 14/3 w/g cable) to the inside unit, what if any type of disconnecting means could be installed inside ? Thanks.
