Ront
New User
- Phoenix, Arizona, USA
How to calculate minimum allowable fusing for 3 strings of 6 modules each string?
Start with the Isc number on the back of the module or its data sheet and multiply it by 1.56, and then go up to the next standard fuse size. That is the string fuse size.How to calculate minimum allowable fusing for 3 strings of 6 modules each string?
That would be the maximum fuse size.It should be listed on the label on the back of the module.
