The county I am wiring a detached garage for is following the 2008 NEC.
The customer would like to have the minimum service required to pass code.
I dont believe from what Ive read in the 2008 code that I can just run a 12/3 circuit to a double pole single throw switch and feed two circuits from that anymore. Im gathering that I will need to set a 60A panel with a gr rod and It dosent have to have a main if its less than 6 throws right. I would like it if I could run the 12/3 but I dont think I can.
If I do have to set a 60A panel can I just make it one ungrounded conductor 120v and feed a main lug panel with 2 breakers and a gr rod.
