I am a NYC electrician new to the NEC can someone tell me the minimum size conductor to be used from the load side of the meter pan to the line side of the disconnect. We used #6 THHN and fused the disconnect with a 60A circuit breaker which feeds a 6/3 to an apartment panel. is this acceptable and where can I find the minimum size requirement in the 2002 NEC
Thanks for your help.
Frank B.
Frank B.
