Minimum Wire Size for OCPD to Motor
ken44
Austin, TX
I have a stand-alone A/C unit(Liebert) it has a minimum OCPD requirement of 25.4 amps but the unit itself has a built in 100 amp OCPD which is itself fed from a 30 amp circuit(from the panelboard) and is fed with #10 AWG. The main fan motor has an FLA of 11.0 amps. There are two other identical units which have # 4 AWG and #6 AWG.
The unit tag says (maximum 50 amp OCPD.)
What size wire is correct for this application?
Re: Minimum Wire Size for OCPD to Motor
I think you may be reading the tag wrong or it has been made wrong.
Most unit tags have a "Minimum Circuit Ampacity" (MCA) Rating and a "Maximum Overcurrent Device" rating.
25.4 sounds like a MCA rating and that would mean a 12 AWG would be acceptable.
You need to look at the tag to find the overcurrent device type and size.
Wire for the minimum, protect at the maximum.
So, if the minimum branch circuit rating is 25.4-ampere, Table 310.16 permits #10, 75 degree conductors. The OCPD can be nameplate or in this case 50-ampere. :)
I have no clue what the 100-ampere breaker is all about? :confused:
Oops :eek: I read that as 24.5 not 25.4, use 10 AWG minimum as Bryan has said.
[ April 26, 2004, 06:50 PM: Message edited by: iwire ]
I can only assume that the 100 amp breaker has to do with in-rush current to prevent nuisance tripping. Other than that, I have no clue myself but all the units come that way from factory for some unknown reason.
Ken44,
If you could provide the exact model & serial number, I could obtain the proper factory requirements for you.
SBE
SBE
That is the one thing I didnt write down! I have made my decision, I am going to reuse the #10 and install a grounding conductor.
