brian john
- Kilmarnock, Va
- Retired after 52 years in the trade.
Also, the equpment seems to have a lot of loose red arrows floating about. You might want to vacuum those out.![]()
Well, let's see.
Pix #3, I'm going to say the bolts are not threaded all the way up, so they installed washers so they could tighten the nut down.
Pix 2 Steel washer between the conductor termination connector and bus.
Minimal load at time of IR, no thermal image generated by the thermographer.
Picture #1
No crimping
Picture #2
Washer between the lug and bus, causing the lug to not make proper connection to the surface of the bus.
Picture #3
The lugs are not making proper surface connection to the bus, which can under load create excessive heat.
I have not seen an installation like this before.
Nice pictures Bryan.
Well, let's see.
Pix #1 is obvious. Someone forgot their crimp tool that day.
Pix #2, hard to tell if it's not a Bellevue washer.
Belleville is the type of washer. Bellevue is a mental hospital in NY. Please elaborate.
You took the bait for post 13 you are surely jinxed now.I used to live at Bellevue.![]()
Why did they spray paint the inside of that cabinet black...a California thing.:grin:
Nice try Pierre. But how about code articles that prohibit this!
nice try pierre. But how about code articles that prohibit this!
