- Placerville, CA, USA
- Retired PV System Designer
How do you have four supply lines to a delta configuration ?
The original post did not specify wye or delta, so many of the answers have covered both separately.
You can have a wye-wired load on either a four wire wye source or a three wire delta source. Whether the latter is a good design or not is an open question.
And you can connect a delta wired load to the three ungrounded wires of a four wire wye source.
