ptonsparky
Tom
- EC - retired
What is your reference for voltage imbalance if the applied voltage is supposed to be 240 +-? You are getting more now. Where does it ask for Line to Ground voltage?If that were true, then why does it have a <3% specification on voltage imbalance? The compressor may not care, but the low voltage boards do. There is some digital communication on the power lines implemented, so this is where I think the weakness comes in. Go back to the link above and read the other thread. It's pretty relevant.
A buck/boost will make your L-G worse. An isolation transformer will help your electrician get his kids thru college, but have at it.
What are you using for backup heat? Gas?
Does this unit have gas heat for backup?
