fairchid45
can you mix aluminum with copper for feeders including the ground
fairchid45 said:can you mix aluminum with copper for feeders including the ground
LarryFine said:Pete, wouldn't it be more accurate to say you cannot mix parallel conductors on the same phase, but you can on different phases in each set?
In other words, all A-phase conductors of different sets must match, but A-phase's and B-phase's conductors need not match in each set.
(To me, 'set' means a group of one conductor of each phase and a neutral.)
