I have a 230' long run from a main panel to a workshop subpanel. The panel will be 240v/125a. The engineer is calling for 3/0 aluminum due to voltage drop. There is NO WAY to get a 3/0 aluminum wire under any lug that will fit in a Siemans 200 amp panel. If I switch to copper, I can run 1/0 for the 2 energized lines then run aluminum for the neutral and bond. The cost of the 1/0 copper is substantially more than the 3/0 aluminum, but it will save headaches in the future. I cannot find anything that says I can't do this. These will be separate feeders in an underground sch 40 pvc pipe. Any input?
