Nietz001
- St Paul MN
I have a 120 volt ac roof top unit with 24 dc controls. Can I install them in the same raceway as long as both of them have insulation rated for 600 volts? We have several opionions within our group.
Most AC units have a Class 2 power supply for the controls. If so see 725.136.
Don's reference puts the nail in the coffin for most installations.
There is no code rule that says you can't mix AC and DC. All of the A/C controls I have worked with were AC.^ If this doesn't apply, then my answer would be that it isn't about mixing voltages amplitude since your insulation is the equal, it's about mixing AC power with DC power.
Standard practice is no. I've never done it.
ETA: It might be obvious to others, but I've never done A/C circuits. We're talking 24VDC digital signals?
