al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
The Minnesota Department of Labor and Industry, which includes under its umbrella, Electrical Licensing and Inspection, publishes a quarterly newsletter titled the CCLD Review.
The issue just released (Summer 2009 edition) has an electrical Q & A that I found notable. This answer is coming from the AHJ for most jurisdictions in the State of Minnesota, and is a departure from "before".Its purpose is to inform construction and code professionals about the purpose, plans and progress of the Construction Codes and Licensing Division.
Q: When a new outlet (i.e. point on the wiring system at which current is taken to supply equipment) for a receptacle, smoke detector or gas fireplace is extended from an existing branch circuit in a dwelling, is arc-fault circuit-interrupter (AFCI) protection required for the entire branch circuit, per NEC 210.12? What if an AFCI device was not available for the existing electrical panel?
A: No. The National Electrical Code (NEC) applies to NEW installations. Existing electrical installations that do not comply with the provisions of the current code shall be permitted to be continued in use unless the authority having jurisdiction (AHJ) determines that the lack of conformity presents an imminent danger. See Annex H (Administration and Enforcement) in the NEC for more information about existing installations and additions, alterations, and repairs. Annex H is not part of the requirements of the NEC. Annex H is a model set of rules that could be adopted by a jurisdiction for the administration of an electrical inspection program. It?s meant to be informational only.
The 2010 National Electrical Code Committee Report on Proposals (ROP) is available online.
The 2010 ROP contains the proposed amendments for the 2011 National Electrical Code. Several proposals for the 2011 NEC dealt with AFCI protection and existing branch circuits. Code-Making Panel No. 2, in its panel statements, have consistently stated that ?The decision on applying the new construction AFCI requirements to a circuit modification is that of the authority having jurisdiction.?
