Mobile Generator Grounding
madmike
2005 NEC 250.34 sez that a connection to a grounding electrode per 250.52 is not required as long as (a), the unit only supplies vehicle mounted, or cord and plug connected loads, and (b) non-current carrying metal parts are bonded to the generator frame. Are there any possible touch voltage issues with this type of installation?
Thanks folks,
MM
Re: Mobile Generator Grounding
Hmmm, I don't understand how grounding the generator will change anything? The neutral is grounded to the gen frame which is metal and the frame usually sets on the ground.
John,
Yes, there is some contact with the earth in that case, but many of the portable generators that are now being sold do not have a neutral to frame bond.
Don
Assume the generator sets on a trailer so it is insulated from the earth. (Also assume no ground connection).
If you create a path from the generator hot lead to the earth (possibly through your arm and legs), no current will flow because there isn't a return path for the current to flow back to the generator. (Current must flow in a complete circle per Kirchoffs current law.)
Ground the generator neutral, and then the above situation causes a shock.
Steve
