please forgive me its been awhile since i did any of this.My question is this i have a mobile home in a court thats has been updated to a 200 amp serviceit has a outside main panel and the 200 amp panel inside the home originally they ran the 200 amp SE cable to power the inside box.But i know it must be a 4 wire feeder my question is this after running a fourth insulated wire can i use that as the insulated neutral and use the bare aluminum wire from the SE as the grounding conductor or am i permitted to just use the SE as it is and use the fourth conductor as the ground?
