electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
To confirm, when the negative Voc temp efficient is a lower number, that means the module loses less voltage as the ambient (and/or cell temperature) increases, correct?
I see in some modules that the Voc and the Pmax temp coefficients don't correspond necessarily, and I was wondering why? Some modules have a low voltage temp coefficient but a higher % loss on the power temp coefficient than other modules that have a higher voltage temp coefficient lose (if that makes sense). Is it the cell technology and resistance to current flow within the module?
Sent from my SM-S918U using Tapatalk
