The title here may be well known and an old, "sore" subject to most electricians in the "real world". I would venture to guess that most electricians know that most conduit that is buried in the ground has water inside the conduit and that the purpose of conduit is for mechanical protection, not moisture prevention. Again, for the most part.
The issue, however, is beginning to gain momentum in the nuclear power, electrical generation realm and electrical engineers are being asked by the "regulator" (NRC) and other operations and maintenance personnel to address the long term effect of observed water found in conduits via manholes or trenches while digging, etc. on the ability of conductors to perform there intended function, safely and within the conductors "design" basis. I am not an engineer but believe that the issue is dialectric strength of wire immersed in water over a long term. My question to the engineers in the wire manufacturing industry or otherwise is "can you point to industry "white papers", or other technical articles on this subject. "
I would like to refer this data to the nuclear industry for consideration and further interpretation. Thank you for any and all technical input.
