Is is permissible to cut off an L6-20P connector from a molded power cord and then connect to a 32amp European connector?  The power cable is made of three stranded cables most likely 12AWG.  The receiving connector takes 1mm^2 to 2.5mm^2 wire.  Are there any issues?  The power cord feeds a 20A PDU and it has the wrong connector but the right PDU configuration.
