Monthly Demand Load question
Telaid
I have a building that has a connected load of 38kva and need to submit an application for monthly demand as kw/month. Not sure how to correctly do this. Seems simple but any help would be appreciated.
Thanks
Ron
Telaid said:
I . . . need to submit an application for monthly demand as kw/month.
That unit of measure has no physical meaning. It is like trying to measure your car's performance in terms of "miles per hour per month." Perhaps you meant "kw-hr/month"? That would be a measure of the monthly energy usage.
I am not sure I understand what you are looking for. Can you tell us what this "application" is all about?
The application is for a new service for a commercial customer. Im guessing there form is incorrect and they mean kwhr/month but just wanted to make sure there wasent something i was forgetting.
the commercial customer in your area might also have a 'demand charge' included in its monthly bills, hence the need for the (max) kW/month demand. our commercial and industrial customers here have that charge, in addition to the usual kW-Hr charge.
the reason is that the utility will supply a transformer based on the demand the customer will submit. and the supply contract will also contain the clause that the customer must adhere to the contracted demand (i.e. max kW/month) or get a new contract/transformer if his demand has exceeded the contracted capacity. A useful tool for the utility if they need to upgrade their facilities in an area.
Robbietan has the right idea on the demand charge. They are asking you what you think the maximum kW the business will be using. A demand meter will take that maximum value and will store it until it is reset by a meter reader each month, and the customer will receive a demand charge each month in addition to total consumption (kW-hrs). However, the utility should be able to estimate what your maximum demand (kW) is going to be, simply by looking at a similar business of a similar size and how many kW they are consuming. If your NEC load calculations comes up with 38 kVA of connected load, I would think your max kW would be around 20 kW (without knowing any other information based on experience).
What kind of business?
This is actually part of our load letter.
