I am fitting a new control package (KE2-Therm Evap efficiency) to a condensing unit. 9hp unit, Compressor RLA of 33.2 with two compressor fans which together total a FLA of 5.4. (the spec sheet for the unit says MCA 46.9 MOPD 80A) the question is, can I use a 63A C or D curve breaker ahead of the compressor /fan contactor so I can use a comb busbar for all the breaker distribution? (SE Multi9 series only goes to 63A in 9mm pitch)
