More than one wire in a lug
tom baker
Bremerton, Washington
Master Electrician
Noted Ilsco has a new insulated splice connector that is rated for multiple wire sizes in one lug. Seems really usefull...
Looks like an Isco ad picture I don't see mounting screws in the boxes. These MAC connectors will trip up inspectors
Looks like a variation of the Alumiconn, which comes in 2-and 3-port versions. I use them on 12v wiring on my bikes.
Because they are set screw connectors ie like a lug. The basic rule is one wire per lug
I get that. Alumiconns come with three ports, too, which is what I used on my bike for direct power to relays.
I was referring to the no-mounting-screws comment.
I can see how this would work for stranded conductors. But it seems to me that with solid conductors of varying sizes, it's possible to come up with a geometry where one of the conductors is loose. I'm really curious to see what the hole looks like in that lug.
UL Recognized 'rail mounted terminal strips' have allowed multiple conductors per set screw opening for years. Maybe UL has changed/harmonized some of their listing requirements?
But up to four of different sizes? I thought the most was two of the same size.
I looked up the catalog sheet out of curiosity ... https://commerce.ilsco.com/documents/PDF/TechnicalDrawing/MAC.pdf and find it clearly confusing ... #6 to #18 solid CU, #6 to #12 AL ... probably because #12 AL is the smallest size?, and #6-#14 stranded. This assumes they mean stranded by FLEX.
Nothing about mixing sizes or stranded and solid, but AL and CU in the same port is not allowed.
I’m really curious as are others to see this device. I read it stated up to (4)#14 wires per port. Surely it isn’t a standard round hole like a grounding bar
No, they mean finely stranded like DLO. Their literature include a table describing the allowable number of strands. There's also a chart listing every combination of solid and stranded allowed in one hole. With a finely stranded conductor, it's just one conductor per hole.
Cheers, Wayne
Explain how a set screw lug EVER puts even pressure on all strands. It never does. That’s part of why the failure rates are so high.
My point is, that at least with stranded conductors, the wire strands can move to conform to the space as the lug screw is tightened. Now imagine 3 solid #10 conductors and a solid #12. in a single port. It seems that such a configuration could easily leave the #12 loose.
FWIW, I have never had a connection fail with a single stranded conductor in a screw lug.
